Do the fans run when AC is off? If only when the AC is on, maybe it’s warm where you are and the fans are helping AC.
If the fans run with cold engine and AC off, have you checked the coolant level? Not just in the recovery bottle but in the engine itself. When the engine’s cold, remove the pressure cap. Coolant should be all the way to the top. If it’s low, you have a leak or the pressure cap isn’t holding pressure.
The engine temp gauge isn’t accurate. You should check engine temp using a scanner that can display live data. That’s what the engine computer sees and how it controls the fans.
Sixto
‘04 LE FWD 196K miles
Sixto
