I have a HK4 hardwire kit for Viofo 229 plus dash cam. Where would be the best place to connect the Battery and Acc on the fuse box under panel of the driver side?
Thanks
Thanks
That's the plug for the OEM dashcam. It's tucked in with one of the wires up there.PS: what is the blue connector plugs into? or it just an extra plug hanging there ?
I'll start with the parts that are needed.
Pormido Hardwire kit: LINK
Toyota F-Connector Housing: LINK
Female Pin Connector: LINK
On the blue accessory plug, there are 3 wires that goes into it with the orientation being: BLACK (12V Always On), PINK (12V Ignition), EMPTY SPACE, and then WHITE w/ BLACK STRIP (Ground).
PICTURE OF BLUE PLUG
On the Pormido hardwire kit, there are 3 wires: YELLOW (12V Always On), RED (12V Ignition), and BLACK (Ground). The yellow and red wires comes connected to fuse splicing connectors, and the ground wire has a grounding terminal. Cut off all of these things from all three wires. And then attach the Female Pin connector to each wire.
PICTURE OF CUT WIRES
Test fit the empty F-Connector into the Blue Accessory Plug and make note of orientation of the plug. Now take the Pormido hardwires with the newly attached female pins on, and push them into the F-connector in the same orientation as how you want the wires to match up with the wires on the Blue Accessory Plug. YELLOW (hardwire) to BLACK (blue plug), RED (hardwire) to PINK (blue plug), SKIP ONE SPACE AND LEAVE EMPTY, and the BLACK (hardwire) to WHITE/BLACK STRIP (blue plug).
PICTURE OF F-CONNECTOR W/ WIRES INSERTED
Plug everything in and now you're done.
Goodluck with everything. It was fairly easy and straight forward. I wish someone had written up a detailed instructions like this when I was doing it. I had to piece meal together from a bunch of different posts on the forums to figure everything out. Cheers!
