1 - 11 of 11 Posts
My big green just arrived at dealer.
I will begin the Digital rear view mirror retrofit project. I still have located a cheap mirror.
Updated with part list
Below are the parts you will need for this retrofit.
1. Digital rear view camera- 867C0-08010
2. One additional washer nozzle- 867F1-08010
3. New camera mounting plate- I can’t find the PN
4. New washer fluid splitter valve- 867FB-08040
5. Digital rear view mirror- 87810-08130
Camera lens Reflex camera Camera accessory Wood Digital camera
Wood Bumper Bicycle part Automotive tire Automotive exterior
Will update when I get the camera installed in the lift gate first.
Houston we have a problem.
Despite being told by Toyota tech and also looking up the rear harness. There is no 4pin connector in the back for none DRM cars.
Also- quick caution
1. Do not disconnect the camera without disconnecting the battery.
2. If you do- you will need to call up service menu to recalibrate the rear camera.
I need to tear into my other sienna to see where the 4 pin connector is.
Which Siennas are pre-wired for the digital rearview mirror? All Limiteds & Platinums, just the ones with the Entertainment system, or something else?
I actually don’t know now.
there are two version of rear harness.
86184-08691(or 90)- which does have pre-wire for the digital rear view mirror
86184-08681 (or 80)- which does not have pre-wire for the digital rear view mirror.
I had always assumed 81/80 aren’t on platinum/limited. We all have 90/91. But when I opened up my cypress today. Can’t find that 4pin. I will need to check my ruby flare.
Toyota updated part and drawing about 3 weeks ago. Now it shows two different wiring now for platinum and limited.
I also need to look into roof harness now. Given I am not sure if roof harness also have variation.
mucho headache
XLE/XSE has different harness too.
I have to tear into both van to figure out.
It's funny, I was going through your parts list checking things out and thinking to myself, "this actually isn't all that bad of a price..." then I got to #5. So annoying considering the relatively inexpensive option when the van is built (if it were actually available).
Discussion Starter · #7 ·
So I have bad news.
It looks like Toyota de-content the wiring as well. For none DRM cars. Toyota did not provide the 4 pin video cable for the connection of the camera.
I will need to take apart the roof wiring to see if the wiring exist on the roof.
So I have bad news.
So you have two vans? One that is DRM optional and one that is not?
Discussion Starter · #11 ·
Three! Wow...save some for the rest of us! LOL.
So sounds like they used the non DRM harness once they realized they wouldn't be shipping with DRM. :(
Yes- all to save like $5.00. While we need to pay $400 for a new harness. Hopefully the roof is there.
I am putting project on hold until I can find cheap mirror. Not in mood to spend $2100.
1 - 11 of 11 Posts
