I would imagine that mice had chew the wire somewhere and that creates a short.
Agreed. Now the challenge is finding where. Might be multiple locations. Fun stuff! More on
how, below.
I would strongly recommend - DO NOT even try to turn the light on until you find and fixed the issue. Otherwise, you're exposing your van to catch the fire instantly.
Nah. That's what fuses are for. That's what protects against fire. If it blows instantly, there is no more current flowing and no more danger. That's why you
NEVER NEVER NEVER replace a blown fuse with a larger fuse. Not even to test, or to limp home.
Ryan, this is not conceptually difficult, but it's tedious work finding that short. It can take a while. If you take it to a shop, they will not give you an estimate, because they can't. It's just pay by the hour until they find the problem. Since few mechanics really understand electricity, they will most likely be shotgunning and it will be expensive. (If a shop
does give you an estimate on this kind of problem, walk away! They have no clue what they are doing!)
If you want to do it yourself, here are a few tips:
First and foremost,
get a notebook! You need to do a lot of testing, and you WILL NOT remember what you did and what the results were.
Write it down! This notebook is a great place to record your plan. "Plan?" Yes, you are going to make a plan, and follow it. You are not going to just jump around, guessing here and guessing there. More on that later.
You'll need a meter, AND a test light. A cheap meter will do for this.
Get a bunch of fuses of the correct size, OR SMALLER. Smaller is actually better - you want to blow them quickly. You are going to go through a bunch, so get cheap ones. I would not use no-name Chinese knock-off fuses in my car, normally, but for this, they are perfect. You can find them in bulk online. Get at least a 10 pack, and more is better. OR you can use a buzzer. More on that below.
Now, you are going to be changing fuses a lot. I'm not sure where your blowing fuse is located. According to
this, it's in the fuse block in the engine compartment. If so, that's easy. If it's up under the dash, that's another story. IF that's the case, use the buzzer trick.
Now, wherever the fuse is, you might want to cheat a bit. Get a
buzzer and a couple of
male .110 quick disconnects. Crimp the connectors to the ends of the buzzer's wires and insert them in place of the fuse. Now, instead of a fuse blowing, the buzzer will sound. Once you have it fixed, the buzzer will stop. (The wires are pretty fine, and wont' fill up the connector well. You'll need to strip back about a full inch of insulation, and fold the wire over two or three times before you put it into the connector to crimp. Twist it tightly, first.) These buzzers draw a very tiny amount of current (12 mA for the ones I linked above) so you are not going to burn anything up. You'll just be annoyed by the sound!
Okay, with everything ready to go, remove ALL of the interior light bulbs. It's entirely possible that one of them is shorted internally. It happens. If the buzzer shuts off when you take them out, there ya go. Just start putting them back one by one until you hear the buzzer again.
If not, leave them out, and now the fun begins. More later, as I have to run now.
