2016 Toyota Sienna LE FWD
That is most likely the timing cover leaking, the 2GR-FE's are very common to leak from that area on the timing cover.
If it is the Timing Cover to fix it would require an engine out job as it is not possible to repair in the vehicle. If it is not leaving puddles on your drive way just monitor it every oil change.
Reactions: vanlyfe2021
