Not true for all scenarios. Many variables such as temperature or battery SOC will force start the ICE but if those are met, then EV mode is available.
From the owners manual (page 236):
■Situations in which EV drive mode cannot be turned on It may not be possible to turn EV drive mode on in the following situations. If it cannot be turned on, a buzzer will sound and a message will be shown on the multi-information display. ●The temperature of the hybrid system is high. The vehicle has been left in the sun, driven on a hill, driven at high speeds, etc. ●The temperature of the hybrid system is low. The vehicle has been left in temperatures lower than about 32°F (0°C) for a long period of time etc. ●The gasoline engine is warming up. ●The hybrid battery (traction battery) is low. The remaining battery level indicated in the Energy monitor display is low. (P.122) ●Vehicle speed is high. ●The accelerator pedal is depressed firmly or the vehicle is on a hill etc. ●The windshield defogger is in use.
Also:
Switching to EV drive mode when the gasoline engine is cold: If the hybrid system is started while the gasoline engine is cold, the gasoline engine will start automatically after a short period of time in order to warm up. In this case, you will become unable to switch to EV drive mode. After the hybrid system has started and the “READY” indicator has illuminated, press the EV drive mode switch before the gasoline engine starts to switch to EV drive mode.
Yes, the gas pedal. . Seriously, there is no "switch"; those are included in plug-in vehicles. Remember this about hybrid driving: ALL energy comes from gasoline. This includes the HV battery.
EV mode is best used for VERY short driving/start up scenarios when you don't want to use gas or an unnecessary startup such as: moving it out of the garage/around the driveway, parking garage, etc.
Without using EV mode, I have driven in EV mode for more than 8 miles a day for the last year and a half. if you keep the fake tach gauge below the C in "eco", it won't start the ICE unless you need heat or the traction battery is low. I can drive from my warehouse all the way home without touching gas if I want to, but it is a bit slow to get to 40mph. its also hilly, up and down, so on the down parts, the traction battery really charges up.
Do you mean you drove for 5 minutes only in EV mode ? Are you sure its all EV mode ? How fast were you running. I could never do that even if i tried. Has anyone else done this before ?
It's possible if
1. The EV battery level is good
2. The water temperature is good
3. The speed is within 35 km/h
4. You feet is soft enough
5. There is no uphill or you will have no need to accelerate
I use the EV Mode all the time (in Canada) and find it pretty useful:
a) I have left the van on my driveway during the day and want to park it in the garage at night
b) Backing out of the garage to load up the van (and it's warm outside)
c) When leaving a parking lot with all the stop and go
d) Low speed zones (example: schools) where I will be slowing / stopping frequently
To answer the original question, there is no way to forcefully charge it. The engine, brakes and coasting charge it.
I do wish there was more capability with the hybrid system. There seems to be so much potential here if we could just get an increase to the battery life, like if we could add an additional battery pack or something. I know it's not going to be an upgrade, but perhaps in the near future the Sienna will get the lithium ion batteries and more charging capacity.
