This issue has been posted before, but since it's a potential engine killer I thought I'd mentioned it again.
Returned home and smelled coolant on my 09 Sienna LE with 208k miles. Pop to the hood to hear phft, phft, phft and could see coolant leaking from below the air intake hose between the throttle body and air filter housing.
I'm lucky I didn't have a catastrophic failure causing the engine to overheat.
Remove the battery, air filter housing and intake hose to the throttle body, that gives you plenty of room to replace the faulty tee. I replaced both plastic tees with the 3/4 inch brass barbed tees. I reuse the original hose clamps and the hoses were in great shape it was just the tees that crumbled.
Joywayus 2Pcs 3/4" ID Hose Barb, Tee T 3 way Union Fitting Intersection/Split Brass Water/Fuel/Air https://a.co/d/efdfa6G
Both plastic tees crumbled as I was removing them, the replacement was long overdue. You also need to be careful removing the broken part of the tee from the hose, you don't want any of those plastic parts to fall into the hose. It was a pretty easy repair, all fixed within an hour.
The tee which has turned brown was the one that failed.
Now to get the mental strength to replace the passenger side axle, air hammer and sawzall on hand.
