FS: New Superbright CREE 9005/HB3 High Beam LED headlight bulb + harness + DRL Module
3285 Views 4 Replies 2 Participants Last post by  NewToyotaFan
4
Got these a couple of weeks ago and had them mounted in the high beams of my Sienna. However got lucky and was able to snag a OE HID headlights so have no need for these.
These are genuine CREE 9005/HB3 bulbs, very very bright and were imported directly from Taiwan. These are a direct fit in the 2011+ Sienna. Will also fit other makes/models if your headlamp is a 9005.
Also included is the relay harness and the DRL LED module. The entire kit is Plug-n-Play. Paid over $85 for everything, asking $55 shipped to the continental US only.
Wire Electrical wiring Cable Technology Electronic device
Product Light
Light Headlamp Automotive lighting Flashlight Photography
Product Tire Red Yellow Light
Re: FS: New Superbright CREE 9005/HB3 High Beam LED headlight bulb + harness + DRL Mo
Both DRL and high beam work on those bulbs?
Yes Both DRL & High beams, just as stock. I also had dual (amber/white) turn signal lamps and they both complimented each other pretty good
Do you happen to have a picture of them while they were on your sienna? What color is it anyway?4300? 5000? 6000?
My bad, the thought didn't cross my mind. It is 5000K
