201 - 220 of 237 Posts
2006 LE
So just driving around here locally in N.Carolina my fuel dipped to 16-17 mpg. The roads are not as flat as Miami !
2008 XLE FWD - ~160k miles. For the last 4 tanks I've manually calculated the MPG vs the computer. I am resetting the computer MPG when I fill up the tank. I'm finding the computer is consistently reporting 4-5 mpg LESS than what I calculate. The last tank, the computer said 18.1 and I calculated 22.4. Similar experience with the previous tanks. Driving mixed between in town and highway.
Anyone else experiencing similar results?
Cory
2006 LE
Cory, one thing I find with my computer ( 06 LE ) is that it stays fixed on a value from a previous drive. So I do a reset whenever I want to check the mpg for a particular trip. Mine is usually within 1-2 mpg. After a tank fill up I occasionally get different values for distance to empty ( DTE) . I really don't know what parameters the computer is looking at to arrive at this value although I suspect it takes a snapshot of the last computer calculation for the average mpg.
Did a long(ish) road trip (234 miles, up into the mountains) this past weekend. I dumped a bottle of Techron injector cleaner in the tank and filled up. All highway driving pushed me to to an all-time high of 20.99 mpg. My normal in-town driving is around 13-14 mpg. I gotta figure out what is causing my high fuel usage. I feel like I should be getting 4-5 mph higher for all types of driving. I lost the lead foot of my youth.
2006 LE
Hey BillG
We both have 06 LEs. I think you should be getting at least 24mpg at highway speeds 65-70 mph. Are you able to see your fuel trims while driving?
AWD or FWD? Your numbers are not terribly out of line for AWD.
-Mike
2006 LE
Azul yours is a 3.5L engine. 04-06 had the 3.3L engine. Getting 17 mpg around town is not bad at all.
2007 Sienna Limited AWD
Brand new we were getting 19 city and 22 highway, about 3 years ago we were getting 14 city 16-17 highway. I replaced the plugs, 3 rear coils, changed differential oil, transfer case oil, transmission fluid and coolant and it got better. It can probably improve if we change our driving habits :).
I have a 2008 LE, 85K miles on it. I just bought it, runs great. But I put a full tank of gas in, and used the gas till the gas light came on, and my reading was 241 miles for that tank of gas. With a 20 gal tank, that comes out to 12.1 miles per gallon.... Anybody care to enlighten me? No CEL lights on, OBD reads everything in the green. Starts right up, runs quiet, doesn't burn oil.. Any suggestions on how I can increase my mileage?
I have the same issues with a 2004 Sienna LE IT runs smoothly no engine roughness great pick up. Any help would be appreciated
2006 LE
06 LE .I just did a 4500+ road trip. As to be expected the mpgs varied with speeds I drove. There was a long stretch that the speed limit was 55mph and I did just that and the van gave 30mpg and even if the gas pump turned off early and perhaps a gallon short it would have been 27mpg.. When I cruised about 65-68 it gave me 27 mpg. After a long highway drive then around town it was down to 22mpg. So 25-26 mpg is pretty much what I expect and plan on. Not bad for a 15 yo van
