1 - 12 of 12 Posts
I just upgraded from a 2004 well-loved Sienna to a new-to-me 2017 Gen 3. Love it so far!
I'd like to drain & fill the transmission, but it appears with the new transmission intro'ed that year, Toyota also rearranged the transmission placement and as a result, the fill plug is harder to access than with previous gen 3 models (based on comparisons to online instructions). I can get a 24mm socket onto the fill plug, but there's no room for the wrench. What's more, there's a suspension/body beam underneath that makes it impossible to fit a standard wrench straight on. Photos attached below. Any suggestions for the best tool to remove the plug bolt? Thanks!
45575
45576
How about an extension? Maybe even a deep socket.
Good idea opening the fill plug first!
Thanks for the idea. A deep socket wouldn't even fit in the limited space.
I just ordered up a low profile 24mm 3/8" socket on Amazon. Will report back after try it, but I'm optimistic as at least one reviewer bought the same to remove the fill plug on their Toyota truck transmission.
Looks like you are using an impact socket. Those things are pretty oversized for this application. I'm sure a standard socket and a wobble extension will improve your odds.
Discussion Starter #9
I was able to successfully remove the plug with this low profile socket along with a standard 3/8" wrench (and an extension!). Of note, the 2017 transmission uses a 10mm (outer) transmission drain plug rather than the 6mm on previous year models.
Discussion Starter #10
Looking at the picture, a swivel adapter should work just fine. I have these Swivel Adapters in my tool chest and have often used these in tight spaces with success.
Also, the swivel adapter I picked up didn't work, it was just too tight; but that might've been cuz I was using an impact socket (though not a deep one by description).
I think you mean the 6mm hex needed for the tube (or "straw") in all Gen-3 Siennas. There's still a 6mm hex tube, used to drain and then set the proper fluid level, in the 8AT drain, isn't there?
Discussion Starter #12
There is still a 6mm hex tube, inside the opening covered by the 10mm drain plug. From what I've read online, prior year transmissions used 6mm for both.
1 - 12 of 12 Posts
