Has my 2021 been reliable by Toyota standards?
1 reading
340 views 14 replies 8 participants last post by  circus
So axle started leaking at around 140,000 miles, and then died at around 190,000 miles. Replaced the axle with aftermarket. At around 210,000 miles struts gave up. Couple of days later I noticed ATF leak around the transmission area. I have reasons to believe the shop that replaced the axle caused this leak and the Toyota cannot be blamed for it. They probably pushed the axle too hard and damaged that seal.
After I replaced the struts, the van drives like new. Last week I changed the transmission fluid and the coolant.
I'm still on factory brakes, and fellow member here tells me I'm good for another 100k miles.
So what do you folks say, what's the verdict? Has my van been reliable?
#3 ·
So other than oil changes, you have replaced struts & cv axles in more than 210K of ownership on a vehicle used commercially.
Are you trolling!!! If not what do you think? Which other comparable vehicle comes to mind that would hold up well to what the Sienna is subject to daily since day1?
You're right, I shouldn't complain. Maybe because that axle replacement and the leak fix really hurt financially.
#4 ·
There is no way around wear & tear of mechanical components which is factored into cost of ownership. On a vehicle that sees such a daily use, I think your van did well especially since the vehicle is also exposed to salt in winters. As for the finiancial hit, again, you budget for it. To make it less painful, just deposit $5 into a separet account (or even a piggy bank) daily, and use it when you need it. If unused, it will make a nice downpayment on the next vehicle.
I can echo some of the frustration on the Axle seal. Went through it myself twice but the 2nd time, the seal replacement was a whole lot quicker plus the exeprience was invaluable. Lesson...replace both at the same time when the driver side is due.
With regular maintaainance, you should go past 300K. Not sure about the aftermarket CV axle though. Their life-span is usally a couple of years depending on the source. Labor, even with indies is getting very expensive (sign of times) and its only going to go up, so DIY is the only path to relief provided you can and are willing to do it.
#5 ·
My 2019 Rav4 xle hybrid at 163k had an corroded power cord dealer quote $6,700 to replaced over warranty by 63k. Toyota stepped in and reduced it to $1,950. Brake replaced front 90k and back at 140k. Gas tank replaced free at 50k. Vehicle built in Japan. Rest routine maintenance. Traded it on my Sienna a month ago 2,700 on it so far.
Based on your experience and mileage I would say overall very reliable.
#13 ·
Huh. Our 2011 has 90K miles on it, has had half-shafts replaced (a while ago, maybe 60K?). That seemed low to me, but it was under (extended) warranty so I didn't much care. Dealership replaced CV joints first, despite me suggesting it was the half-shafts, so I got those free too. Your results seem not bad to me, for a LOT of miles in not very long!
