1 - 1 of 1 Posts
This to me is a constant issue with Siennas of any year, I've owned from 1999-2015 and all have too much front roll. WILL AWD struts fit my 2015 2WD model LE? IF so, are they stiffer, taller, better? I'm trying to get a heavier duty strut like a Bilstein maybe, and if a bit taller even better as long as alignment stays good and tight. IF not the AWD strut idea, what have you found to be the most robust front Sienna strut? I hear at times other vehicle struts being used but am not sure on this model. I would tend to go with a KYB but which model? Are quick-struts NOT recommended for some reason like the springs are not up to par? I hope to replace the rubber cushion parts for optimal resilience and no creaks etc, thanks for your suggestions.
1 - 1 of 1 Posts
