1 - 13 of 13 Posts
had this happen after a drive way car wash. restart the car then everything back to normal.
Hi ! I disconnected parking sensor. When I got this problem ( Pre-collision malfunction) , I checked sensor when I put selector to reverse, sensor works perfectly. I think the problem with the module Pre-collision.
How to reset system?!
How to restart the car?! Connector should be ok, I keep it focus when assembly back
a simple restart is to turn the car off, leave it a few minutes and turn back on
If after doing this, the car still malfunctions, then you did something wrong. Go back and check your wiring.
Also, (sorry for my poor photoshop skills) around the back there are two square black boxes behind the bumper, if you moved them, or if there is an obstruction, or a wire that goes over said box, it will alert you that its not working correctly.
If you moved them then a recalibration will be needed and that is done by the dealership
Automotive tail & brake light Tire Vehicle Grille Automotive tire
Discussion Starter · #8 ·
I will check on weekends and let you know.
I think the wires touch the box .
We will see. I will share a photo for your guys.
Thanks guys
Discussion Starter · #10 ·
Hi guys! I figure out what wrong, but I don't know how to solve the problem ((.
Today I disconnected back bumper, changed position of all wires, for prevent touch some parts ( but previous position was perfect).
Automotive tire Hood Motor vehicle Automotive design Automotive exterior
Hood Automotive tire Motor vehicle Automotive lighting Automotive design
Automotive tire Sleeve Dress Grey Wood
Bicycle tire Automotive tire Motor vehicle Automotive lighting Hood
Hood Automotive tire Motor vehicle Automotive exterior Bumper
But when I install back bumper, and trying to turn on ignition the error messages pop up again.
The I connected reader they showed next error code
Rectangle Font Screenshot Number
Rectangle Parallel Font Pattern Paper product
Rectangle Font Screenshot Number Parallel
Rectangle Font Parallel Pattern Paper product
I think the problem with Stop Lamp Relay Actuator Stuck On
Right looking for how to solve this problem)
If not figure out I will connect all light with towing light
If you have this problem let me know. Thanks
Going back to your original message it seams like you installed a wiring harness for towing. And from the looks of your error codes, something in the wiring harness is shorted to ground.
My suggestion is to remove what you installed, plug everything back in. If the error codes go away then your connections are shorted.
Those error codes are being thrown because something is grounding the harness.
1 - 13 of 13 Posts
