Hello, I have not been able to figure this one out. I have a 2006 AWD LE and I want to add a Traction Control disable button. Apparently, AWD vans do not get the Traction Control disable feature. However, behind the location in the dash where the button would be installed there is the plug where the button would be installed. I purchased an OEM button for the location, plugged the harness into the button and nothing happens. So, I assume something must be "turned on" inside the computer in ordered to enable the button. Does anyone know if the computer is able to be changed to accept the button? Thanks!
