How to remove dash vents?
1 reading
13K views 6 replies 5 participants last post by  Sienna_250
My A/C vents on the far right and far left have kind of fallen apart. I want to pull the vent to see if I can fix them, but I can't figure out how to pull the vents.
I've tried to do some searches, without any luck. Can anyone offer any advice how to get the dash vents out?
Jamie
#4 ·
Center Vent
1. Remove two torque screws in upper corners of vents. guys I have noticed in my travels, one or two instances where the center vent in a jetta had these two torx screws in place. They are a PITA to remove since you can't easily remove them. I suggest taking a good look through the 'louvres' of your vents to see if you see anything that looks like a screw back there, prior to yanking the vents out. IF, and its a big IF, you see screws in there - you'll need to carefully pull the front fascia of the jetta vents off the housing, then remove the louvres and then undo the screws. PM me for help if you need it***
2. Carefully remove all of the buttons by prying behind them with a little screwdriver. The hazard switch and rear defrost will be mighty hard to get off. Undo the wiring harnesses for the witches, and store the switches in a safe place.
3. If you can’t get a switch out, you should be able to get the whole vent out and remove them from the rear. The top of the center vent should come out towards you a little bit, then the bottom should release itself from their clips. Again - a putty knife can help get under the edge and help the vent out - be careful not to damage the soft touch coating, patience is key.
4. Once out, you should be able to pull the vents out just enough to undo the harness for any stubborn switch, and then get the switch out. The problem with the above mentioned switches is they are held in with metal springs that are very tough to get out.
