1 - 1 of 1 Posts
I have a 2001 CE. The main lights behind the dash are not working. I checked the dimmer switch, the fuses, and replaced the bulbs behind the dash, but still doesn't work. Any ideas?
I was thinking about picking up an instrument cluster from the salvage yard, one with a tachometer, to see if that works, but then I realized that might change my odometer to whatever the newly installed cluster has. Is that what would happen?
The gear indicator lights and warning lights all work, just not the lights behind the speedometer, odometer, fuel gauge, and temperature gauge.
1 - 1 of 1 Posts
