I just used regular rca spliced into the wires in back of mini info screen for my nex5000 works great. Don't really need an adapter.
Sent from AutoGuide.com Free App
What method DID work for you? Do you remember? I've seen most of the references people point to like the link above (alexapps), but people still report failures while some say it works....I'm wondering if it just comes down to loose taps, incorrect wiring, or bad solder (shorts too?). The whole 12V vs. 6V argument doesn't seem resolved in most forums either....but as EthanSienna said, different trim packages may present slight differences in wiring, combined with the various head units people have installed.Here's the article that been referred to in other posts. It shows how its author replaced his stock radio with an aftermarket unit and how he connected the stock backup camera to it. For whatever reason, however, his method for backup camera connection didn't work for me in my 2013 LE with my Pioneer AVIC-8000NEX.
http://alexapps.net/toyota-sienna-aftermarket-gps-navigation
I haven't attempted any other method yet. The summer heat has made sitting in a parked car for hours not very attractive. When the weather cools a bit, I'll try again.What method DID work for you? Do you remember? I've seen most of the references people point to like the link above (alexapps), but people still report failures while some say it works....I'm wondering if it just comes down to loose taps, incorrect wiring, or bad solder (shorts too?). The whole 12V vs. 6V argument doesn't seem resolved in most forums either....but as EthanSienna said, different trim packages may present slight differences in wiring, combined with the various head units people have installed.
Did u ever successfully install the backup camera??I haven't attempted any other method yet. The summer heat has made sitting in a parked car for hours not very attractive. When the weather cools a bit, I'll try again.What method DID work for you? Do you remember? I've seen most of the references people point to like the link above (alexapps), but people still report failures while some say it works....I'm wondering if it just comes down to loose taps, incorrect wiring, or bad solder (shorts too?). The whole 12V vs. 6V argument doesn't seem resolved in most forums either....but as EthanSienna said, different trim packages may present slight differences in wiring, combined with the various head units people have installed.
