A leak started on the floor in front of passenger seat. Had the A/C drain tube pulled and cleaned. Now it also is wet on the driver side. Only wet on the floor on both sides, no moisture can be found coming down the wall under the dash. Dripping is not noticed. Ideas?
Wet with coolant (pink, in the case of Toyota), or what appears to be plain water?
Coolant = heater core leak.
Water = condensation from the AC system that is not draining. Recheck that condensate hose, and run a coat hanger up into the bottom of the HVAC box. Chances are you still have a clog and the unit is holding water. The box is multi-piece and has seams that will leak out into the floor. If the level gets high enough, it will begin finding it's way into the ductwork under the floor and front seats and head to the back.
