I had this problem twice in the last 2 weeks and wondering what's going on.
When I start the engine, starter motor only makes one weak cranking noise (sounds like battery is too low and starter motor cannot crank). But if I turn ignition key back to ACC and try to restart immediately, starter cranks normally and engine fires up without any problem.
After the first problem, I thought battery level was too low because I was blowing A/C fan without engine running in the hot parking lot (BTW, battery is 2 years old from Costco). So I used battery tender to charge up and there was no issue for about 2 weeks.
When the 2nd problem happened, van was just parked on the driveway for ~1 hour after driving on the hot day. After the problem, I opened hood to measured battery voltage level with DMM and it was 12.6V (looks normal). I also checked battery voltage with OBDII scanner and it said 11.6V (slightly low?). I thought ~1V drop in the voltage level was unusual, so I did following experiments.
a. Recharge battery with battery tender again. Battery was 12.3V and ODBII reading was 12.1V.
b. Checked battery voltage overnight in the morning. Battery was 12.0V and OBDII reading was 11.7V. (No issue with start up).
c. Recheck battery voltage after driving ~20 minutes. Battery was 12.8V and OBDII reading was 12.2V (Alternator seems to be working)
Because engine starts normally after the 2nd startup attempt, I think battery is okay. Alternator seems to be okay also.
Could this be starter motor or relay problem?
