We just found out that 2007 Sienna LE leaks from this radiator hose. I believed this is the return hose.
We took out this out from the radiator and it was very loose. That explains why it was leaking. We're not sure why it leaks in the first place. The question is, is there a way to fix this without placing the radiator? Right now, it seems the radiator thread was stripped.
If we can't easily fix this part, what radiator part number should we replace? Is this the radiator assembly, No. 2 part#: 160410P201 the correct part? This is a 2007 Sienna LE 3.5L, I think. Another question is, does this kit, part#: 160410P201, comes with everything I needed to replace this leaking hose radiator? Do I need to purchase the above nut bolt that I took out separately? Thank you so much for any tip!
