I've been reading all I can find on lifting our FWD Gen2 Sienna XLE a bit in an effort to improve the ground clearance and load carrying capability of the van to facilitate boondock camping and general outdoor exploration. We're not looking for rock-crawling, just the ability to better handle rutted, muddy roads like those found in the BLM and national recreation area lands of the western US while hauling a rear hatch kitchen and associated camping and outdoor gear. This forum has been a great help and I'd like to share what we have learned.
As many know, the ground clearance on the Sienna is poor, especially in back when loaded. To address that I've decided on three approaches:
1. Adding strut and spring spacers for a modest lift front (30mm) and back (50mm).
2. Swapping in 1999-2004 Honda Odyssey rear springs
3. Using the 8-passenger/AWD rear shocks
The lift parts (30mm front and 50mm rear) were sourced from the Russian supplier Tema4x4 on eBay that has been discussed here on SiennaChat previously. Shipping was slow but the parts arrived in good shape and look to be of good quality. I have all the parts on hand to install but have yet to do so. I will be doing this myself and will share the results here, minus the 4-letter words inevitably required.
If buying from Tema4x4, be sure to share your VIN with them as the models the various parts will fit are not abundantly clear from the descriptions.
Tema4x4 link:
https://www.ebay.com/str/tema4x4
The Odyssey springs are nearly the same length and diameter as Sienna springs, but the Odyssey spring is 442 lbs/inch versus the 350 for the Sienna.
Specs on Odyssey springs:
https://www.fme-cat.com/overlays/part-detail.aspx?brandId=MC&pNum=80661&partType=Coil Spring Set
Specs on Sienna springs:
https://www.fme-cat.com/overlays/part-detail.aspx?brandId=MC&pNum=81411&partType=Coil Spring Set
Evidence suggests that the stock Toyota springs for AWD and 8-passenger or mobility models are different (stiffer or taller or both) than the standard springs so I've decided to use KYB shocks in back from the AWD model to help handle the stiffer Odyssey spring. Specs on the two models show that the AWD shock is slightly longer with a longer stroke although valving information is not available. Time will tell how that works out.
KYB AWD/8-pass shock:
https://shop.advanceautoparts.com/p/kyb-gas-shock-344480/20740413-P
KYB FWD shock:
https://shop.advanceautoparts.com/p/kyb-gas-shock-344308/19171741-P
To improve our boondock camping experience we are also building a rear hatch kitchen that will add around 150-200 lbs of permanent weight to the back, hence the lift and stiffer springs.
Rear kitchen for the Sienna:
Lastly, another aspect of the build is to accommodate a taller light truck tire in the future once the current tires wear out. After getting stuck boondocking on muddy forest service roads in AZ this spring and the hassle of getting pulled out we look forward to the increased ground clearance and traction. Additionally we are going to be welding on hard-points for recovery extraction as well as have assembled a recovery bag that includes tow straps and a manual chain hoist to pull the van out unassisted. I'll share those efforts once finalized.
Thanks for making this site a great resource, and stay tuned for more...
Tema4x4 link:
KYB FWD shock:
