1 - 10 of 10 Posts
LIRCd.conf and RMDU for 2011 2012 Toyota Sienna XLE/Ltd DVD Entertainment Remote
I captured the remote with irrecord for LIRC, and used lirc2xml/lirc2rmdu to generate an JP1/RMDU (remote master) file
LIRCd.conf
# Please make this file available to others
# by sending it to <[email protected]>
# this config file was automatically generated
# using lirc-0.9.0-pre1(default) on Thu Aug 23 18:31:29 2012
# contributed by: ramuk
# brand: 2011 2012 Toyota Sienna XLE & Limited DVD Entertainment Wireless Remote Control
# model no. of remote control: CY-KT4060AJ
# Toyota Part Number: 86170-45070
# Battery markings: DC3V/R6P
# devices being controlled by this remote: 1
begin remote
name siennalircd.conf
bits 16
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 9005 4525
one 539 1699
zero 539 581
ptrail 546
pre_data_bits 16
pre_data 0x1E7
gap 108038
min_repeat 1
# suppress_repeat 1
# uncomment to suppress unwanted repeats
toggle_bit_mask 0x0
begin codes
POWER 0x30CF
DVD 0x18E7
SPLIT 0x946B
VIDEO 0x48B7
CHAPTER+ 0x50AF
CHAPTER- 0xD02F
FOLDER+ 0x728D
FOLDER- 0xF20D
TOP_MENU 0x58A7
MENU 0x9867
PLAY_PAUSE 0x7887
REW 0x38C7
FFWD 0xF807
OPTION 0x8877
SIZE 0x6897
DISPLAY 0xA857
UP 0x04FB
DOWN 0x847B
LEFT 0x44BB
RIGHT 0xC43B
end codes
end remote
Siennaremote.rmdu
Remote.name=RS 15-135
Remote.signature=30853085
DeviceType=DVD
DeviceIndex=2
SetupCode=1234
Protocol=00 5A
Protocol.name=NEC2
ProtocolParms=128 231 null
FixedData=21 FE 18
Function.0.name=CH+
Function.0.hex=AF
Function.1.name=CH-
Function.1.hex=2F
Function.2.name=POWER
Function.2.hex=CF
Function.3.name=PLAY
Function.3.hex=87
Function.4.name=PAUSE
Function.4.hex=87
Function.5.name=REW
Function.5.hex=C7
Function.6.name=FFWD
Function.6.hex=07
Function.7.name=MENU
Function.7.hex=67
Function.8.name=UP
Function.8.hex=FB
Function.9.name=DOWN
Function.9.hex=7B
Function.10.name=LEFT
Function.10.hex=BB
Function.11.name=RIGHT
Function.11.hex=3B
Function.12.name=SELECT
Function.12.hex=EB
Function.13.name=INFO
Function.13.hex=57
Function.14.name=EXIT
Function.14.hex=A7
Function.15.name=B[blue]
Function.15.hex=E7
Function.16.name=C[red]
Function.16.hex=6B
Function.17.name=GUIDE
Function.17.hex=77
Function.18.name=DAY+
Function.18.hex=8D
Function.19.name=DAY-
Function.19.hex=0D
Function.20.name=D[green]
Function.20.hex=B7
Function.21.name=SETTINGS
Function.21.hex=97
Function.22.name=SPLIT
Function.22.hex=6B
Function.23.name=VIDEO
Function.23.hex=B7
Function.24.name=DVD
Function.24.hex=E7
Function.25.name=Folder-
Function.25.hex=0D
Function.26.name=Folder+
Function.26.hex=8D
Button.4=Folder+|null|null
Button.5=Folder-|null|null
Button.6=CH+|null|null
Button.7=CH-|null|null
Button.3=POWER|null|null
Button.35=SELECT|null|null
Button.28=INFO|null|null
Button.26=MENU|null|null
Button.31=UP|null|null
Button.32=DOWN|null|null
Button.33=LEFT|null|null
Button.34=RIGHT|null|null
Button.61=EXIT|null|null
Button.27=GUIDE|null|null
Button.f=PAUSE|null|null
Button.c=PLAY|null|null
Button.b=REW|null|null
Button.d=FFWD|null|null
Button.38=D[green]|null|null
Button.2e=B[blue]|null|null
Button.2b=DAY+|null|null
The LIRCd.conf file is a direct capture of the remote itself, this way the remote could be used to control programs on a linux computer (such a one running a media center like:
http://www.raspbmc.com/about/
http://www.lirc.org/
The RMDU file, I'm not sure works. If it does it could be used to program a universal remote with a JP1 port using the REMOTEMASTER software
http://www.hifi-remote.com/wiki/index.php?title=Remote_Master_Manual
http://www.hifi-remote.com/wiki/index.php?title=JP1_Introduction
This would help defray the cost of a lost remote ($200 for an IR remote, REALLY!?!?)
The next task would be to see if it can be added to Logitech's harmony database, as the cheapest harmony remote (the 200) is only about $19 Dollars.
Works for All in one 4 Simple. I was able to program it and needed to re-add just a few functions but this helped out a lot. Thank you!
Here is a complete list of remote codes for Highlander 3rd gen RES remote, they should work for Sienna as well:
power toggle: 1E7B24D
power off: 1E78C73
audio output: 1E7B44B
settings: 1E78877
dvd: 1E718E7
dvd: 1E70EF1
sd card: 1E76E91
display: 1E7A857
av settings: 1E754AB
up: 1E704FB
down: 1E7847B
left: 1E744BB
right: 1E7C43B
select: 1E714EB
vol+: 1E7609F
vol-: 1E7E01F
rew: 1E738C7
play/pause: 1E77887
ffwd: 1E7F807
chapter+: 1E750AF
stop: 1E7B847
chapter-: 1E7D02F
top menu: 1E758A7
title menu: 1E79867
1 - 10 of 10 Posts
