Re: Low engine oil pressure & charging system lights after putting back the air clean
Jerry,
Did you check the fluid levels for Oil and transmission fluid? When I start my car, the battery and oil light come on at startup and then go away.
Since you disconnected the battery, the computer has been reset and it will need to re-learn. I think you are ok to start the van. The lights should go off after the van starts up. If they don't then shut it off immediately.
Note, if it's really cold, then the oil light might stay lit for more than one or two seconds. Last week when it was -25 C, my oil light was on for about 10 seconds before it went off.
Regards, JC.
Jerry,
Regards, JC.
