Maintenance required light
16809 Views 6 Replies 5 Participants Last post by  zorro_wrangler
Does anyone have the "code" for shutting off the maintenance required lights? Also to shut off the seatbelt not buckled beeps?
I had these for my 2008 but they don't work on my 2013.
:D Thanks
1 - 7 of 7 Posts
Reset the maintenance data (U.S.A. only)
After the required maintenance is performed according to the maintenance schedule, please reset the maintenance data. To reset the data, follow the procedures described below:
Vehicles without a smart key system
Switch the display to the trip meter A (→P. 244) and then turn the engine switch off. While pressing the trip meter reset button (→P. 244), turn the engine switch to the “ON” position.
Vehicles with a smart key system
“ENGINE START STOP” switch off. While pressing the trip meter reset button (→P. 244), turn the “ENGINE START STOP” switch to IGNITION ON mode.
Vehicles without a multi-information display
Continue to press and hold the button until the trip meter A displays “000000”.
Vehicles with a multi-information display
Continue to press and hold the button until “COMPLETE” appears on the multi-information display.
Thank you,royc it works!!
When do these reminders come on I have 15k on my Sienna SE and wondering when to expect it to come on?
On my 2012, the maintenance light starts flashing for a few seconds each time the engine is started at 4500 miles after a reset. At 5000 miles after a reset the maintenance light is lit continuously. Prior to 4500 miles, the light comes on briefly for a lamp check each time I start the engine.
royc
Silly to have a light come on after 4500 miles to tell you to rotate tires. I have to pull out my cheat sheet to remember how to turn the nag light off.
I think the NAG light is a dealer sell tool. I tried to go along with it but the dealer wanted too much of my wallet. I fired the dealer and feel better about my personal maintenance plan.
Can the Maint Reqd indicator show up if you have a radiator coolant level that falls below level? I'm suspecting i have a leak in my radiator as i have to replace the coolant rather frequently. The Maint Reqd indicator has come up after 1000 miles since last oil and fluids change.
1 - 7 of 7 Posts
