Hi, I can start the vehicle however I can't remove the key. I've tried wiggling the steering wheel with no joy.
TIA for any advice.
There's a mechanism in the steering column that prevents key removal when the transmission is not in Park. Sounds like you need to adjust the shift lever housing in the steering column.
Hi, thanks for that. It was in park at the time however eventually after a few more stops along my drive I was able to remove it.
It was a bit unsettling for me though and I appreciate your reply.
If the key gets stuck again, adjust the shift lever housing in the steering column.
