1 - 2 of 2 Posts
Hello,
I have a 2015 Limited AWD and I need help to figure out if it came with the tow prep package. I did research the related threads here but got more confused, I saw some folks posted the oil cooler picture, which is different from what I have. And some thread mentioned that the 2015 has a tow package as standard equipment in US market but not in Canada. I made my purschase from a Toyota dealer in Indiana and I assume it should have the "Standard" package by default.
If my Sienna does have the 3500 lbs capacity, I'm considering buying a TAXA Cricket trailer to tow. it claims has 1800 lbs gross weight and have built in brake controller installed. I'd like to hear if I need Air lift and weight distribution hitch installed.
So far I have installed CURT class 3 hitch receiver and wiring harness. If my Sienna cannot handle any weight above 1500 lbs, I'll stop spending more money on it.
It sounds like you have confirmed that your 2015 Limited AWD does not have the tow prep package. Here is a link to a thread in which a forum member posted a letter from Toyota describing which 2015 Sienna AWD trims have it: Why is the towing capacity of the 2015 Sienna XLE AWD...
IIRC, it was confirmed by Canadian forum members that it's the same for Canada although it would take searching to find those posts.
1 - 2 of 2 Posts
