Hello.I've just purchased a high mileage but well-maintained 2004 Sienna LE which I'm guessing was a base model(?) as it has manual adjusting front seats, a manual left slider and rear hatch and is FWD. I'm using it as a work van - I've removed all the seats other than the driver's to shed weight. I'd like to increase the rear suspension in both capacity and height - I had previously owned a Dodge Grand Caravan and I was able to purchase heavy duty cargo coils and shocks, but I can't find similar suspension components for my Sienna. I've seen the "bumper" kits, and the kits that slip in between the coils, but I'd rather go with stronger coil springs and shocks. I'm pretty sure stock is back there right now. Any helpful suggestions would be greatly appreciated. John
Welcome to the forum. Sounds like you may have a CE model. That is the base in 2004. The AWD rear coils do have a stiffer rate and would be a upgrade. I would also recommend adding a Airlift 1000 inside the coils.
