I just got the car last week with 97k on the odo.
I've already check the wheel alignment, replaced all 4 tires, engine oil change (high mileage oil), coolant flush and replacement, replaced air filter.
I'm planning on doing the transmission oil change and timing belt replacement asap. (as well as water pump w/ gasket, tensioner bearing, and idler bearing)
Anything else i should replace/change while it's in the shop?
I need the car to last a long time so i'm trying to do as much preventive maintenance as possible.
thoughts?
Thanks
PS: the brake pedal feels a bit mushy, is that normal on these van?
I stops the car fine but it's got a much longer action than on my other cars (standard), this is my 1st automatic tranny so wonder if it should feel any different from a standard brake, I don't see why it should but you never know...
Should I replace the brake fluid?
thoughts?
Thanks
