1 - 3 of 3 Posts
After having work done on my ac I now have a problem with no defrost, no air or heat coming from upper vents at the windshield, or floor. But the air and heat is coming from dash vents on side and middle. problem is I can not defrost my windows and windshield when they fog up. Any help or suggestion would be appreciated.
2015 Sienna Limited Premium
You need to begin this story from the beginning. What worked / what didn't before having the work done. What did you have repaired? What happened, and what did the shop say about it?
Everything was okay before I had the compressor changed and system charged. The mechanic says it's the activator door. Before I tackle that job I wanted to know if it could anything under the hood that might have changed how the air or heat flows from the vents
1 - 3 of 3 Posts
