1 - 7 of 7 Posts
When I am making a slow left hand turn my 2015 sienna will make a clunking noise. It's only on left hand turns and it only happens randomly while driving. Most left hand turns don't produce this noise. Video of the noise here:
Any ideas what it could be? Bad tie rod?
CV joint problem.
Intermediate steering shaft.
Could also be the wheel bearings.. Seinna is notorious for bad wheel bearing.. Get toyota dealer bearings.. No amazon or ebay.
This sure sounds like the half-shaft problem. First dealer said "brake shoes", which was obviously stupid. Second said "CV joints", replaced them under extended warranty; nope. Back it went and this time they did the half-shafts and that fixed it. I told them "half-shafts" first visit, so I don't feel at all bad about the free CV joints!
Lots of unclear terminology here.
CV joints are part of the axle "assembly" that comes from the transmission and ends at the wheel hub. These assemblies are also called drive axles or axles, or sometimes drive shafts or half-shafts. When a CV joint goes bad, the whole axle assembly on the affected side is replaced, in one piece. Rarely, if a CV joint's boot is damaged and there are no symptoms, the boot can be replaced. Clicking sounds, proportional to speed, are the classic symptom of a worn CV joint. Another symptom can be vibration on the highway, but vibration has many possible causes. As mentioned above, it could be a bearing; bearings often growl or hum in a rumbling, low pitch, at moderate speeds.
Pictured is a driver-side axle assembly from a Gen-1 Sienna. The passenger-side axle is a little different, and a bit longer, with a tricky bearing and bracket holding it in place under the engine. Axles.jpg
Wasn't the steering intermediate shaft issue resolved by 2015?
1 - 7 of 7 Posts
