No. The TSB is only good for 36 months or 36,000 miles. This does not fall under the powertrain warranty.99Stang said:Excellent - Thank you!
Would this be covered under the 5 year 60k mile powertrain warranty?
That's what I was afraid of.robo5 said:No. The TSB is only good for 36 months or 36,000 miles. This does not fall under the powertrain warranty.99Stang said:Excellent - Thank you!
That was me and it still works like new. Very easy and cheap fix. I got the idea from a Camry forum. All that is happening is that the grease works it way out over time, which is normal. It just needs to be regreased. They should have designed it with a grease nipple for easy regreasing. Here are my posts about what I did including pics:steelcity said:99
There is a post here talking about this problem and some of the members,lube up the u joint in the steering shaft,in fact one member used a syringe full of lube to get in the tight spots which worked great and fixed his problem. I think what is going on here is that u joint is getting dry and then wearing out premature.Hope this helps.
