odd sound coming from the top
2759 Views 3 Replies 3 Participants Last post by  meazz1
2005 AWD Sienna. With no check eng light, I'm getting a sort of rattle sound coming from the area above the timing cover side of eng. Verified is "NOT" coming from under the cover...So not tensioner, belt, waterpump, idler pulley, etc) in which can not be seen under that cover. (the covers was pulled and looked at stuff underneath) Also, those items were replace 6 months ago at 100K miles. Ok, the odd thing is...the sound goes away as soon as eng. warms up.
It takes engine temp to get this sound to go away....no ambient temp. Car acts normal. No abnormal temps. or indications.
A neighbor mentioned a varaible cam spool type sensor. We both doubt this, as no ck eng light.
I doubt a valve, as it does not have the distinctive "tap", unless this lifter would make a different type sound. Guy mentioned to put a pint of dextron 4 in eng oil to clean out anything if depostited. I run 5w-30, as what is recommended, and a good brand.
Almost a gurgley sound, then gradually disipates to normal eng sound. Anyone?
Same on my 05 AWD XLE, notice anytime i push on gas the noise increase or when i first start it up in the morning.
Really? How many miles? Mine has 110K. Same finds with mine, but the noise ceases after perhaps 5 minutes. It is eng. warmth based. I'm speculating the EGR valve, or something to do with this system. If i get time, I'll buy one to try it...if not the issue, will swap back out and return. I doubt I'll do this anytime soon. Keep me posted on your findings. I'm unsure what to think. I was told not to worry about it, though.
Thx, Greg Indianapolis
Similar issue I had with my corolla and turned out to be a bad water pump, bearing or something. I replaced WP and it went away.
