You can try to spray some air freshener down the mesh right below your windshield wiper arms. That black plastic trim with the mesh is where fresh air comes in for the cabin.
Yes there is some stuff on the market for the A/C system that helps the mold/meldew that accumilates in the HVAC system. I bought some stuff from Car-Quest (you can get it at most car-care places) Read the label for proper use of the product. I used up the last of my can in Sept/Oct? so I can't give you the proper name of the product that I used. There are tons of these products on the market. I do mine twice a year (if I remember ;D) both front and back.jh818 said:You can try to spray some air freshener down the mesh right below your windshield wiper arms. That black plastic trim with the mesh is where fresh air comes in for the cabin.
Here's a trick. While it is not raining, but sunny out, spray water on your front windshield and turn on your vents and see if you can duplicate the problem. Just make sure that the outside temp. is not below freezing or you'll be in for a doozy.javastring said:i live in chicago area.
i can understand if this were to happen in summer when AC is used by i wonder what's the reason for in winter time.
