1 - 8 of 8 Posts
I have an 05 sienna and I started having an intermittent OH problem these last few weeks.
We've had record heat in our area these last few months and one day the van OH so I pulled over and added some water. After it cooled down we drove with no issues for a few days. Now rinse and repeat for a few more times. I added antifreeze as well but it still OH.
I've removed as much of the old fluid as possible and replaced it with the Asian brand antifreeze. Whats been happening is even after I did this it's still OH. It seems to go for a couple days with no issues and then it OH. The last time I put it on a hill, engine up, and filled it so the bubbles would work their way out. I thought it fixed the issue but today it did it again. What is happening? Should I buy one of those no spill fiunnels and try that? I'm at a loss for what's going on.
Discussion Starter · #2 ·
Also, one time I checked the fluid with the engine running there was some foaming coming from the radiater cap. There was a lot of bubbling as well. I bought this little bottle from wall mart that fixes head gasket leaks and after about 5 mins the foaming and bubbling stopped. There wasn't any water in the oil or oil in the water. I've only put in distilled water as well. The van has 300,000 + miles on it so I'm not going to spend a lot of money on it.
Had a similar problem with my mom's 06 Limited
Turned out to be an intermittent cooling fan issue.
The housing for the fan motor would sometimes lose connection and cause it to overheat (flex it with your hand and it would start/stop)
Replaced the entire fan assembly as it wasn't available separately and it's been fine eversince
1 - 8 of 8 Posts
