1 - 20 of 23 Posts
Hello,
My 2000 Sienna has been good to me. Have driven her last 30K miles without any issue.
I drive about 30 miles a day.
On my way home from work, noticed that my temp gauge was climbing above the middle. By the time I made it up the hill, it was around 80-85% to the top.
I left the car cool off for about 2 hours. I returned back to the car and saw that the expansion tank for the coolant was empty. I concluded that I must have a small coolant leak somewhere, and that I've finally lost enough coolant to cause me trouble. I filled up the expansion tank to the full line, and drove around for 10 mins.
It seemed fine for about 10 mins, then the temperature gauge started climbing above the middle, and started overheating again.
I turned on the heat inside the cabin to max, and turned on the fans to max (while the temperature gauge was 75%), but nothing but cold air was coming through the vents. Next, I parked the car and opened the hood to expedite the cooling process. At this point, I noticed that the expansion tank was still filled to the full line.
Also, I noticed that the electric fans behind the radiators were not spinning, while the engine was overheating at 75%+.
I scanned the car with an OBD-2 scanner. Interestingly enough, right after the scan completed, the electric fans behind the radiators actually turned on for about a minute, and then turned off. The fans turning on was surprising, because it happened when the car was shut off. Car engine was off, but they key was in the turned position, right before cranking the starter.
What's going on here? Feels like it's a thermostat that's stuck closed ?
Thanks!
David
· Premium Member
2014 Sienna LE
I don't know how the 1st gen coolant system works. On my 3rd gen, and most vehicles I've worked on, the expansion tank will NOT fill the radiator when the radiator is hot! The coolant system is normally pressurized, to raise the boiling point of the coolant. So as it heats up, once the pressure is reached coolant is pushed out of a spring loaded valve into the expansion tank. When the engine cools back off, eventually it'll start pulling a vacuum as the coolant contracts and suck coolant back into the system from the expansion tank.
If 1st gen works the same way, the coolant must fully cool to suck in coolant. If the coolant is low (which it sounds like), in addition to topping up the expansion tank, you must, when the engine is cool, open up the radiator cap and top up the coolant in the radiator directly.
Not to me. Stuck thermostats will cause overheating, but coolant through the heater core is not controlled by the thermostat. If the engine is overheating, and it's blowing cold air on heat setting, that's a coolant circulation problem. This is often caused by lack of coolant, which because of your empty expansion tank it sounds like you have.
Discussion Starter · #7 ·
Your intuition seems to be spot on!
I've filled coolant under the radiator cap, and now all is well. Temperature gauge on dash is sitting in the happy middle point of the range, and the cabin blows warm/hot air when the heater is turned on.
However, I've let the car cool back down to ambient temperature after all this, and I see that the expansion tank level has not moved - it's still full, as when I filled it last night. Could it be that my vacuum lines to suck the coolant from expansion tank to the system are faulty? Perhaps I have too much coolant in the system now ?
· Premium Member
2014 Sienna LE
It’s not possible to have too much coolant in the system. You could add too much to the expansion tank and when the engine heats up the expansion tank will just overflow, no harm done.
The engine needs a cycle from full heat to very well cooled to pull any coolant in. It can take a while for the engine to cool for this to happen. And sometimes if there is a small bit of air trapped in the coolant system it’ll take multiple heat/cool cycles to work out. Just keep an eye on it over the next week or so. Well, actually, because it was empty keep an eye on it till you figure out and fix the leak! Those don’t just go empty for no reason.
It is possible for the line to suck coolant into the engine to get plugged, but it’s unlikely. Especially as the expansion tank was empty. Unless the tank itself had a leak, the tank being empty means the line is working just fine, as your engine was sucking in new coolant to replace the coolant lost in the leak.
Discussion Starter · #10 ·
Ah crap, it's overheating again. . .
Filled the car with coolant from radiator cap, was all good for about 50 miles.
Now she's overheating again. I pulled over, and waited about 20 mins, opened the radiator cap, added some more coolant 50/50, but she didn't take much to be full (since i filled with coolant last night). Overheating again . . .
· Premium Member
2014 Sienna LE
May be useful to change the thermostat and pressure cap like @circus mentioned. I'd definitely try a pressure cap before a thermostat though (see bottom of my post for more details on why).
Have you seen any signs of leaks anywhere? Are you using Toyota Long Life Coolant (LLC)? Use a flashlight at night, look for any red liquid below where you park or on the engine. Look for crystals built up on the engine or radiator too, which are signs of dried coolant, which also indicate leaks.
Did you try running the cabin heat this last time time when it overheated? Could be you have multiple issues, and if with more coolant in the system now, if you were getting cabin heat when it overheated, then it points to a bad thermostat. If you still don't have cabin heat when it overheats, that's pointing to a coolant circulation issue still over a thermostat issue.
OBD scanners are great. I recommend you set it up to display coolant data live, and log it too, if you can. On a normally working cooling system, you should see the coolant temp rise until the thermostat opens fully at which point the temp should level off. For example, here's data from my 2014 as I was monitoring temps to see how long it took for the engine to reach normal operating temp. On my 2014, this is about 185 °F. Watch the blue dots. Note the temp rises and eventually hits 185 °F where it levels off and stays as I continue driving.
Watching your coolant temps and how it behaves may help narrow down the issue. Logging the data so you can graph it later like I did would also be useful.
Electric coolant fans can turn on at any point, even when the vehicle is off (key off). Some vehicles, not sure about the 1st gen Sienna, will occasionally run the cooling fans after the engine is shut off for a few issues. I believe my 3rg gen says it may run the fans for a bit after the engine is turned off, depending on how the engine was used, ambient temps, and engine temp. I drove a 1991 Honda Accord when I was a teen, and on warm or hot days it would always run the cooling fans for a couple minutes after the engine was turned off. I believe this was to prevent vapor lock on a hot engine restart. So many people said "your car is running"...nope, just the cooling fans doing what they do. In any case, on a vehicle with electric cooling fans, always keep fingers and loose clothes away from the fans unless the battery is disconnected, as the fans may engage automatically even if the engine is off.
That said, your fans not turning on when your engine was overheated may be an issue too. Is your drive mostly highway, or is it stop and go? On the highway, the fans should not need to turn on to prevent overheating, but if it's getting overheated they should definitely be turning on. I don't have the FSM (factory service manual) for the 1st gen, but the FSM for my 3rd gen says with the AC off, the cooling fans should turn on at low at 207 °F, and go to full speed at 216 °F. They should start slowing down as it cools to 212, and turn off when it cools down to 203. At this point, the temp gauge shouldn't even have budged off the "normal" location, so by the time the temp gauge starts going up, the fans should definitely be running.
You can download sections of the FSM if you get a 2-day subscription to techinfo.toyota.com (what I do, printing sections to PDF for later use). This will tell you how to troubleshoot the fans and other parts of the cooling system, and what temps the fans should turn on and off at.
Failing that, if you turn the AC on, do the fans come on immediately? The fans should run anytime the AC compressor is running, regardless of coolant temp. If the engine isn't overheated, the fans should cycle on and off as the compressor cycles on and off. If they don't, that would point to a fan issue.
A Little Bit of Cooling Theory:
50/50 antifreeze has a boiling point of 223 °F. Coolant systems are generally pressurized to about 15 psig, which further increases the boiling point to 253 °F. A coolant pump, which is driven off the engine (either by the accessory belt or by the timing belt, depending on the engine), constantly circulates coolant through the engine and the passenger cabin heating core(s). A thermostat is used to allow coolant to come up to the normal engine operating temp of about 175-200 °F, depending on the engine design. There are bypass loops that allow the coolant to flow through the engine and back to the coolant pump inlet while the thermostat is closed.
Once the coolant is hot enough, a thermostat will start to open, allowing coolant to flow into the radiator, or from the radiator (depending on thermostat location), which brings hot coolant into the radiator and lets cool coolant flow into the engine. The thermostat is a simple mechanical device that uses wax melting and freezing to open and close the valve. This action is proportional, allowing the valve to be fully closed, partially open, or fully open depending on coolant temp. If everything is working correctly, it will maintain the coolant temp at the design temp.
Fans on the radiator are used for additional airflow. Originally, these were engine driven fans, generally with a clutch to engage or disengage them. Now, they are pretty much exclusively electrically driven. They run when the AC compressor is running, regardless of coolant temps, otherwise they only run when the coolant gets too hot, which is some point above where the thermostat is fully open. When driving on a highway, there is plenty of airflow from driving, so the fans aren't needed. They are only used if the vehicle is driving slow or stopped, as there is insufficient or no airflow to maintain coolant temps in these cases.
Coolant always circulates to the heater cores in the passenger cabin, regardless of coolant temp, unless the car regulates heat into the passenger cabin by a coolant flow valve instead of using the traditional air mix damper, which isn't common.
If a vehicle overheats, but full cabin heat is requested and it blows hot air, this indicates a thermostat and/or fan issue, as the coolant is circulating fine if you are getting cabin heat, but it's not being cooled sufficiently.
If a vehicle overheats, and full cabin heat is requested but it blows cold air, this points to a coolant circulation problem, because if coolant isn't circulating, you won't get heat to the heater cores, so no hot air will blow from the vents. Coolant circulation problems are generally due to air in the coolant system caused by low coolant, because air in water pumps makes them work poorly, or not at all. Since the coolant pump is driven off the engine (except some modern cars will use electronic cooling pumps), it can't be the pump itself has failed, unless it seized and a belt is slipping, but you'd definitely hear that and your belt wouldn't last long...
My Thoughts:
A failed pressure cap could cause these issues, as with no pressure the coolant may start boiling and creating steam pockets in the coolant, which could lead to circulation issues. So replacing the radiator cap wouldn't be a bad idea.
A coolant leak will definitely cause these issues, so the leak MUST be found and fixed!
It certainly won't hurt anything to change the thermostat, but I can't see that being the issue based on the information you've provided about your problem. If you decide to change it anyway, just for kicks I'd throw it into a pot of water and put it on the stove with a thermometer. If it starts opening around 180 °F, the thermostat was fine.
The vent mentioned by @circus is a good point too. This vent (called a jiggler valve) allows air trapped in the system to help work it's way out of the system. This vent must be installed facing up when the thermostat is installed. Here's a picture of the thermostat I installed in my 2014, as I changed the thermostat when I changed my water pump, because I had to remove the thermostat anyway for that job. The jiggler valve is correctly installed at the top of the thermostat. It won't do it's job if it's not at the top when the thermostat is installed.
Discussion Starter · #12 ·
My Thoughts:
The vent mentioned by @circus is a good point too. This vent (called a jiggler valve) allows air trapped in the system to help work it's way out of the system. This vent must be installed facing up when the thermostat is installed. Here's a picture of the thermostat I installed in my 2014, as I changed the thermostat when I changed my water pump, because I had to remove the thermostat anyway for that job. The jigger valve is correctly installed at the top of the thermostat. It won't do it's job if it's not at the top when the thermostat is installed.
@jseyfert3 you sir, deserve the keys to this fiefdom.
😊 😊 😊 Me and my wallet are so happy that you responded to my plights.
Managed to limp Bessie to my office parkade.
Will roll-up my sleeves and replace the following soon:
  • radiator cap
  • thermostat
  • water inlet gasket
Will update with results. Stay tuned !
· Premium Member
2014 Sienna LE
  • radiator cap
  • thermostat
Hopefully it all works out!
If you don't get a Toyota thermostat, I'd recommend getting an Aisin one, it's likely OEM for the Sienna, but even if not they make a lot of parts for Toyota. Change the thermostat gasket (is this what you mean by water inlet gasket?) too while you're at it.
Product Rectangle Font Line Screenshot
Old Sienna
  • radiator cap
  • thermostat
I don't know if yours has the 1pc plastic thermostat housing or the 2pc metal thermostat housing like my 99. If yours is metal it's a good idea to replace the o-ring between the thermostat housing and the tube that the radiator hose attaches to.
Discussion Starter · #17 · (Edited)
@jseyfert3 - Ok, I think I understand what the root cause is.
Every time Bessie would overheat while driving (all in the last 3 days), I would change gear shifter to Neutral, and then shut off the engine. Shortly after, I would come to a stop. I would get out, and open the hood to speed up the cooling process. Each time I did this, I would smell this hot cotton candy smoke wafting out from the engine.
I think the Water Bypass Hose has ruptured, and is leaking into the 'V' of the engine, and burning off, creating this cotton candy smelling smoke. Mind you the smoke is visibly faint, but the smell is pronounced, and definite hot cotton candy flavour.
Water Bypass Hose - Toyota Part Number: 16261-20010
Slope Font Parallel Auto part Diagram
Font Magenta Auto part Cylinder Titanium
Video of someone facing this issue:
* * * I have not confirmed if this is the root cause for my overheating problem * * *
The last thing I did:
Installed the new radiator cap, then drove for 2-3 mins to a covered parkade.
Once in the parking stall, I turned the cabin heat to max temp, and vent to high. I let the engine temperature (according to dash gauge) rise up to 50%.
Icy cold air was blowing out my vents. I think I'm losing coolant, and not at a low rate.
· Premium Member
2014 Sienna LE
This thread shows similar coolant leaks, on a later engine (the 3MZ-FE, not the 1MZ-FE you have). Gen 2 Coolant leak following knock sensor replacement
If that's anything like my 3rd gen with the 3GR-FE engine (yet a further gen engine) getting access to that will be fun. Just did my spark plugs and it required removing wiper cowl, wiper mechanism, lower wiper cowl, the air intake, air intake filter box, and finally the air intake manifold. Below that is the air intake plenum, fuel injectors, etc that must be removed to gain access to the valley.
If it's not the hose, sounds like it's something there for sure! I'd get it fixed ASAP and not keep driving it. Overheating can cause lots of other issues. And if the coolant gets too low, it can stop circulating entirely and the sensor can indicate the coolant temp is fine (because it no longer has coolant by it) even though the engine is destroying itself from heat.
Good find and keep us posted!
Kinda thinking that there is a bit of a oil leak around the thermostat area and made the seals swell. It is old. Change the thermostat. The GEN1 bleed very easy. Next step would be to make sure the fans are working and in good shape.
I think I have a similar situation as you.... engine overheat....turn heat on and sometimes heat comes on and temp goes down, other times just cold air..... but if I play with temp dial from cold to heat....the cold air turns to heat and temp gauge goes down.... its weird..... but I haven't had real chance to look yet.... its work in progress
it happens worse on stop and go traffic.....better when car is frwy going...typical coolant behavior. The radiator fan works so that's not the issue...it turns on when it overheats...
Does the temp dial switch have something to do???
I did feel the radiator hoses... and top one is warm or hot.... but the other one to thermostat is cold or cool to touch without hot burning.... so I think its the thermostat going bad....or something else... might help if I burp the air out of the radiator coolant.... I do know there's a small leak going into the valley at top 2 valve cover gasket area...
My plan is to change out the thermostat, gasket and see if the water pipe to thermostat is cracked or not. and then whole coolant replace, flush......and then it will be time for the timing belt whole replacement again....its at 270k miles...last time I replaced was at 150k miles....so its due for it... still curious about the gasket coolant leak at top 2 valve cover area....called the valley....but I don't think its the cause of overheat...... wondering if water pump failure....don't think so.... either way...it will be down for while for maintenance and repair...good thing I got spare car.....
I hope the coolant didn;t mix with transmission oil to make milky transmission oil that plagues some toyotas....
1 - 20 of 23 Posts
