Before you fire the parts cannon, you should know that there are 3 different possible problems (maybe more) here. The valley cover can leak coolant into the area, the harness can be shorted (rodent damage) or the sensor can be failed. All three can throw the same code. Unfortunately, the only option I know to verify which problem it is, is to take it all apart and visibly inspect to eliminate the wire harness and coolant leak options. To do that requires probably 2 hours of disassembly. Other than that, I can't provide any insight into those sensor options, as I've never had to replace one on my van.
