1 - 2 of 2 Posts
My 2006 was coding P0741 TCC solenoid stuck closed for a few weeks, I moved from Virginia to SC without issues, once in SC it didn’t code out but broke down on the interstate, trans just stopped working.
Dropped the pan, changed the filter, TCC solenoid and replaced 5qts new fluid. Closed it up, started her drove her out the driveway a 1/2 block and stopped again, no D or R, reverse feels like there is a brake on. What did I do wrong? Should I have changed out the SL solenoid instead?
Any advice will help.
I'd have it towed to a transmission shop or Toyota dealer for proper diagnosis. It could be a number of things, but most will result in the replacement of the transmission or the junking of the van. What was the condition of the fluid when you drained it? Did you get out the anticipated 4.3ish quarts from the drain, much more, or much less? It sounds like the transmission is slipping out of gear when it warms up and the fluid thins out.
1 - 2 of 2 Posts
