again, gasoline is a strong solvent, and the stuff in those little bottles is not gonna make it stronger, nor will it dissolve anything that the gasoline would not already dissolve. Gasoline was originally used as a solvent and was a byproduct of making diesel fuel and heavier fuels. In fact, it was also used as Lamp/lander fuel before it was used in cars, and was sold as "whte gas". Its also called coleman lantern fuel. there is nothing you can add to gasoline that will dissolve anything more.
We’ve tested a bunch of pour-in fuel additives in Fact or Fiction over the years. Can you really blame us? With all their promises of horsepower and torque incr
www.motortrend.com
They don't work like they claim, and would need to be so strong in order to function as described that they would harm you car's emissions systems badly. and they legally cannot be sold that strong due to environmental regulations, and the fact that they would likely dissolve the plastic bottle they are in. Even seafoam, which is good stuff, is more or less just another gimmick that really doesn't do much in the concentration that its sold in(this is also why you need to "hot soak" your engine with it for it to actually work properly).
secondly, in the new siennas case, its both DI, and PI. The port injectors will keep the valve top's from getting carboned up, so you should really never need an induction cleaning service at all, and if the DI injectors are "clogging", it means that there is poor combustion happening, which would have a root cause that you would want to figure out, but the main reason for poor combustion is usually crappy gas, and at that point, because of the way the injectors work, you cannot clean them without fully disassembling them and putting them in an ultrasonic cleaner. if it can't push it out the holes, its not gonna come out no matter what you throw in there. those little bottles of "mechanic in a can" shit have been mostly snakeoil for decades. its an easy upsell for a shop to charge you $50 for an "injector cleaning" when all they do is dump a bottle of mystery fluid in your gas that cost them $3, and that is basically like a drop of piss in the ocean in concentration in your gas,
which is already a very strong solvent.
