1 - 9 of 9 Posts
The trunk area in my 2022 XLE doesn't have much lightning. Would be useful to have better lighting when unloading things at night. What do you use to get more light back there?
Did you turn the light on??
I pick up my van at 1 mile ..yes (one mile) and the light in the rear closest to the hatch is off.. all the rear vent were close... so take a look and just turn it on..
Replace bulb with LED and be sure it’s switched to on. Size is 194 LED, IINM
Hood Automotive lighting Trunk Vehicle Vehicle door
Gen 3, same concept. Tapped the rear cargo cables and it comes on when the door is opened or via remote.
I also use this for my hood lights.
PryEU Daylight White 6000K LED Strip PryEU Daylight White 6000K LED Strip Lights 12V for Interior Car Automotive Boats Motorcycle Lighting 12'' 30CM 2835 SMD UL Listed Pack of 4 https://a.co/d/iFt06px
Car Vehicle Hood Automotive design Motor vehicle
· Premium Member
The OEM incandescent light bulb in the very back was quite dim; I replaced it (along with many other bulbs) with LEDs, which are much brighter. Later I discovered that the light had become visibly dimmer, and I saw it flicker as well. I pulled the assembly apart and found that the moving and stationary contacts inside the switch were partially oxidized (where they touched each other' surfaces). I cleaned those surfaces a little and the light has been OK since.
P.S. I sure hope that the rest of the electrical system is of a better quality, because this stuff WAS scary:
Toyota Faces Class Action Suit Over Corroded Cable Issue in RAV4 Hybrids | Toyota Sienna Forum - siennachat.com
Here’s an upgrade you can purchase if you really want more light in the back.
US $59.94 10% Off | For Toyota Sienna 2022 Tailgate Additional Light Trunk LED Light Indoor Atmosphere Light Car Reading Light Car Accessories
Those are nice. Just like the MIT stuff for gen 3, but they're expensive.
My route is cheap and easy to undo. And plenty of light, but not over doing it.
1 - 9 of 9 Posts
