How does one go about initializing the power rear hatch?topspy said:Yes....re-initialize whenever you have replaced or disconnected the battery (and possibly any relevant fuses).
You need to "manually" cycle through the entire fully opened to fully closed sequence for all power windows, power sliding doors, power rear hatch, power moonroof, etc.
YMMV.
Good Luck!! 8)
For some reasons my 04 xle won't close the power lift gate either with the remote or use the button inside the car. I was worried that the motor was dead, but it started working again after the following steps.
Here are the steps I did to get it working again.
1. Unhook the battery neg terminal. ( I left mine unhooked for 3 hours)
2. Open the lift gate manually
3. Push the lift gate next to your left kneed until you don't see any red
4. Hook back the neg battery terminal.
5. Push the lift gate next to your left kneed again. you should see the red now.
6. Either use your remote control or the power lift gate button inside your car to close the power lift gate.
It should work now. That how I got mine to work again.
Hope this helps.
