1 - 3 of 3 Posts
Hello all,
I am having trouble identifying where this noise is originating from. I'm hoping someone else has had a similar problem and knows what is causing it. It could be the idler pulley, tensioner pulley, water pump, power steering pump, a/c compressor, or alternator. I shot a video so you could hear. Thanks in advance for any help given!
Tom
2011 Sienna Unidentified Noise
The waterpump looks like it's running true and that's not the noise I've heard failing Sienna waterpumps make. It sounds more like a failing bearing. So removing the belt and feeling for which pulley, idler, tensioner isn't rotating well is the best route. And while I say the waterpump looks okay, as long as the belt is off make sure to check it as well.
1 - 3 of 3 Posts
