1 - 8 of 8 Posts
Any suggestions on a source for the rear axle beam? My tire is tilted and it looks like the beam rusted out on one side. Is 4211008010 the right part number if I can find one?
That's how my 2001 died. Are you sure you want to try to replace the beam? Everything else will be corroded, too.
If you pay the salvage yard some extra to be careful not to cut the parking brake cables and include the hubs brakes etc, it shouldn't be too difficult to swap. I would do it, but then again, I'm not paying someone else.
:unsure: Hmm, maybe I should sandblast and paint mine. Where do they fail?
While sandblasting and painting the beam I learned a few things. By removing the four bolts holding each hub and supporting the brake back plates the beam can be replaced without disturbing brake lines or cables. No need to buy anything other than the beam.
1 - 8 of 8 Posts
