1 - 11 of 11 Posts
hi guys,
My LED fog light came in and I try to install them but run into something i haven't seen before..
I'm not sure how to remove the plastic piece to open the liner..
Tire Automotive tire Tread Wheel Synthetic rubber
Do i pry if open ?? I was afraid i will break it off....
The other smaller one is easier to remove..
Automotive tire Water Automotive wheel system Auto part Darkness
Discussion Starter · #2 ·
I got it..
Just use a flat piece of plastic trim remover and put that in the line between the fender and liner then press and it will pop out..
The van looks better with LED fog light..
Vehicle Car Grille Automotive lighting Hood
I was able to use both screws on the driver side.. Harbor Freight has a small 90 degree ratchet that works ..it's about $7 and it can be in there to tighten the second screw on the driver's side..
Hood Automotive tire Road surface Motor vehicle Asphalt
Discussion Starter · #7 ·
I believe all the Sienna has the plugs for you to plug the fog light. No additional wiring is required. Other items like dash cam, pudding lights also have the plugs. Just buy the parts and you’re good to go.
1 - 11 of 11 Posts
