Only 2 bolts are visible. I think the other 2 are under the cup holder on the front side. It appears the front portion which houses the cup holder should come off, but it may be attached to piece that goes forward on the floor. It does not slide, it's fixed.lift up the thin peice of felt at the bottom of the console. you will see 4 bolts. unbolt and remove console
Anyone know how to get the cupholder front portion off?You are right. the front cup holder prices in the center console does come off to show the 2 bolts. There’s also a cable for the cup holder light as well.
Be careful pulling out the light and detaching the cup holder light cable... I did that for some project (to run wires underneath it for an amp install I think) and had the hardest time getting it back in properly. Can't remember why exactly.You are right. the front cup holder prices in the center console does come off to show the 2 bolts. There’s also a cable for the cup holder light as well.
