1 - 20 of 25 Posts
So I’ve searched high and low and have turned up zero information.
Has anyone tried, succeeded, or failed with mounting a rooftop tent to their Sienna? I can be the only guy with an AWD Sienna that wants a rooftop tent.
Or am I?
Thanks.
A tent on your roof would probably be fine as long as people didn't get in it. My 2014 Sienna owners manual includes the following text:
"Do not exceed 150 lb. (68 kg) cargo weight on the roof luggage carrier."
There is also a caution from Yakima at https://yakimasupport.zendesk.com/hc/en-us/articles/235808548-Will-a-Roof-Top-Tent-Fit-my-Car- :
"Never use a rooftop tent with any vehicle whose rooftop load limit is under 165 lbs."
I've seen a collapsed minivan roof. I didn't check a rental before I accepted it about 15 years ago and found when I returned it that a previous renter had damaged the roof by overloading the luggage carrier. The rental agency tried to charge me for the damage but I convinced them that I had only carried passengers during the one day rental. As much as the roof was collapsed, I was surprised it wasn't obvious from inside the van.
Don't mix up static and dynamic loads. Dynamic (while driving) load shouldn't exceed 150 pounds. Can you go higher safely? Maybe. Static (parked) loading can be much higher. How high? Who knows, manufacturers don't publish that info. But two people in a RTT on a parked Sienna should be ok. And yes, do not drive with people in the tent!
-Mike
It might depend on how "dynamic" your two people in the tent get! >:)
I love this dialogue. Thanks for the input guys. I can’t believe this haven’t been tried yet...
Here's a fun and informative video about the pros and cons of roof top tents that includes information about static and dynamic loads:
And this video shows 14 pretty amazing roof top tents - I had no idea this was such a developed industry:
One small roof top tent is shown on a Subaru wagon and another on a Mini Cooper. I apologize if this is old news.
This thread reminds me that I have five tents in my storage room ... from a 6 lb. backpacking tent to a huge tent that can sleep 6 to 8. I need to be getting rid of this stuff.
Discussion Starter · #7 ·
Thank you for the video and info. I was suspicious about static vs dynamic. I’m leaning more and more toward this can happen and should be a thing.
I believe the load rating is for the roof rack. The 150 lb. rating is likely designed with a factor of safety such that you could put 150 lbs. the center of the rack and not cause damage. However, I have absolutely put more than 150 lbs. on it, without issue, distributed closer to the outside edges. In addition, I am confident that, if you secured your roof tent platform over the rails rather than the cross pieces it will be totally fine. Depending on how you do it, you could also distribute additional load to the roof itself. I typically buy 3 dozen bags of much every Spring. If I get them a day after it rains, they are dripping mulch-water. I will just toss them right on the roof. I have tossed 4 in between the front and back crossbar and 2 more between the back crossbar and the "spoiler". So, that would be about 200 lbs. of weight directly on the roof sheet metal.
Here are some expensive options... These are some pretty sleek roof top tents.
Auto home us dot com
Don't know why it's rejecting the link...
Or am I?
Thanks.
44646
We have had great success! The static weight limit is 150 but the dynamic limit is not listed
Or am I?
Thanks.
HI there, I am planning to put a 140# Roofnest Falcon on my 2019 Sienna....wondering if you discovered anything about the safety of this decision? Your response much appreciated.
Are you still doing well with this arrangement? I am planning on putting a 140 lb roofnest falcon on my 2019 Sienna....any advice? Thanks!
Donna,
I had the same idea of putting a Roofnest Falcon on my 2012 Sienna. I was thinking of getting in contact with Roofnest. But I hesitate because I kind of know already that they will not commit to saying that it's safe. Have you had any luck getting any feedback from other Sienna owners? I think the one of the issues to consider is that the rails of the 3rd generation (2011- present) only have two points of attachment to the roof. The rail's mid portion is unsupported and therefore less able to support heavier loads. The 2nd generation (2004-2010) Sienna's rails had three points of attachment to the roof. I was thinking of some DIY way to add a third point of support to the midpoint of the rail. Please share any info you may acquire regarding your plan to put a Roofnest Falcon on your Sienna. Thanks.
Donna,
Luna07 had great success with the Classic Tentbox on a 3rd Gen Sienna. I looked it up and the Tentbox they used weighs 64.5 Kg or 141.9 lbs. So that means the 140 lb Roofnest Falcon should be ok also.
Donna,
HI there,
So I did call Roof Nest and they assured me that the 140# Falcom would be fine with my 2019 Sienna 150# dynamic weight limit. I pressed in with the conversation saying some people had reported that they saw problems with the factory rails, but they said they have put a lot of tents on Siennas without issues. They agreed that having a third cross bar would make it even better, but they had no hesitation with just the 2 Thule Evo Wing Bars I have currently. I will put a third cross bar up. I will not put anything else on the roof of course, No awning etc...I may take out the mattress from the Falcom and put in an Exped instead to make it a bit lighter...but I will decide that once it arrives....I am experiencing delivery delays...
HI there,
Appreciate you sharing that info. If it isn't too much of a hassle, please share a picture once you have it on the roof of your Sienna. Thanks
1 - 20 of 25 Posts
