Heya guys, I’ve got a 1st Gen Sienna I’m working on getting back up to speed. I’m gonna ask a few bullet point questions for repair advice!
1. My valve cover gasket is leaking. I already have the gaskets to replace it. My question is, is there anything special I should know, and if there’s anything else I should replace at the same time? I also have spark plugs, so that’ll be a given. I thought about doing the coil packs, but they’re a bit pricey. I heard that Denso made Toyota parts, so if I do replace them, is that a reasonable brand to go with? Edit: it was NGK coil packs I found, not Denso.
2. I’ve got a leak coming through the sunglasses holder up in the front. I believe it may be coming from the roof rails, as it seems the seals beneath where they’re mounted are not in good shape. You guys reckon that’s what it is, probably? Where can I get the seals?
3. I’ve noticed that my horn doesn’t work sometimes- specially while I’m going interstate speeds, when I notice it. Anyone know what that’s about? It works when parked or going city speeds when I try it.
4. So, the seat buckle sensor in one of the seats isn’t working, probably driver. The TPMS system isn’t working, either. Should I simply remove those two bulbs so it’s not bothering me?
