1 - 2 of 2 Posts
I'm still getting used to my "new" 06 Limited. Everything else with the engine appears to be running smoothly. However I've got some likely related conditions. I'm hoping this is just a sign that I need some tuning done, but I can see possible expensive repairs needed and I've only got 10 weeks left on my used purchase warranty.
1) Sluggish initial acceleration ... I know it is a minivan and I'm definitely not treating it as anything but. However even when lightly loaded (ie, just me) the initial acceleration from 0 is pretty anemic. When fully loaded (tested today while ferrying around 7 full grown adults) it is definitely sluggish
2) When going up a hill, for instance stopped on a steep city street in Seattle, I have to hold the brake to avoid sliding backwards (just me in the car, no load) and when going need to use both feet ... 1 on brake slowly releasing while pushing down on the acclerator ... or I slip backwards
3) Reverse on a slight incline (ie, reversing with the rear higher than the front) requires significant accelerator use to get moving
Once I'm up to 10mph everything seems fine -except- in the last scenario
4) Fully loaded (7 passengers) on a fairly steep hill (10% or so) I need to go all the way down to 2nd or even Low to be able to accelerate through 30mph
I'm doing a little more long-distance driving this week to do my final testing before I take it to a mechanic that will work under my warranty plan (typical 3 month / 3,000 mile used warranty). I'm curious what I should tell him to look at first with regards to the above?
1 - 2 of 2 Posts
