I purchased an aftermarket remote start system, which uses the Toyota Smart Key to start the van.
It seems to be a quality product. I removed the lower dash panel (under the steering wheel) to take a look at what I will need to do to install this unit.
It requires splicing into wires on 3 different plugs. I did unplug the Steering Lock Connector, the Push To Start connector and one of the ECU plugs.
After looking at what wires I will need, I plugged them back in and put everything back together. for the future installation.
Now, the doors do not open with the fobs. The doors don't lock or unlock with the fob.
The van does start.
I did just notice the fobs have a faint red light that turns on when push one of the buttons. I don't know if this has always turned on, or I just now noticed it.
I pressed and held both the lock and unlock buttons, trying different things. This is how to unlock all doors vs. only one door. The display did register this action, so that and the fact the van starts, tells me the fobs art still connected to the van.
I cannot figure out how to make the fobs lock/unlock the van or how to make them open the three power doors again.
Any ideas?
The van is a 2011 Sienna Limited
Thank you, Chad
The van does start.
Any ideas?
Thank you, Chad
