While researching and comparing Spare Tire (Donut) sizing to full size 235/50 R20 (Width=Don't Care, Diameter=29.3").
Using Tire Size Calculator, I've come up with 4 options:
Stock: Spare tire is 155/80 R17 (Baseline: 6.1" width, 2.5" smaller diameter compared to Fullsize)
Option 1: Upgrade to 155/90 R17 (Same width (6.1"), 1.3" smaller)
Option 2: Upgrade to 165/90 R17 (0.4" wider, 0.6" smaller)
Option 3: Upgrade Spare tire set with new rim 165/85R18 (0.4" wider, 0.3" smaller, new rim +$$)
Option 4: Upgrade Spare tire set with new rim 155/90R18 (Same width, 0.3" smaller, new rim +$$)
Any and all the above is dependent of Spare tire well fitting. Maybe I can ditch the original hard cover for an oversized shower cap.
Has anyone done this or thought of doing this? What would be a good practical method of checking fitment? There appears to be about one inch around the circumference.
Also to consider, if inflated to 60 PSI, how much diameter does that increase vs non-inflated. I say non-inflated because I typically carry a portable air inflator.
Note: Still waiting for build (12/7/22) + delivery.
