Hello guys, my questions here is about spark plugs, I am due to change my spark plus on my 2003 sienna, I am currently debating weather to buy single ground electrode or dual-ground electrode, or if you can say your expertise on which is better for the engine in terms of performance and fuel economy, my second question is weather the first sienna 1997 to 2000 release ( before the face uplift design ) engine uses different spark plugs than the newer sienna from 2001 to 2003 ( after the design face uplift.)
I did some research online and called dealership but couldn't get a solid answer.
for example amazon...when you enter the years 1997 to 2000 Toyota sienna.. it will approve that this spark plug DENSO ( 3253) PK20TR11 DOUBLE PLATNUM SPARK, fits your vehicle...... however when enter years 2001 to 2003 sienna it gives you a red label which indicated it does not fit your vehicle...
I know that trims on the first gen sienna does change the engine size.
bottom line is I want to know if all spark plugs for the first generation sienna are the same.. if so amazon is WRONG.
here is 2 links to help solve this tiny mystery.
1st link is the dual ground electrode but according to amazon it doesn't fit my 2003 sienna
I would prefer this plug though
Denso (3253) PK20TR11 Double Platinum Spark Plug, Pack of 1, Spark Plugs - Amazon Canada
2nd link is compatible with my sienna 2003 ( according to amazon ) but its single ground electrode
thanks !!!
6 PCS *NEW* - DENSO #4504 PLATINUM T T Spark Plugs - PK20TT, Spark Plugs - Amazon Canada
6 PCS *NEW* - DENSO #4504 PLATINUM T T Spark Plugs - PK20TT in Spark Plugs.
www.amazon.ca
thanks !!!
